Tom's Hardware > Forum > Graphic & Displays > ATI > HDMI audio, with sound card
Forum Graphic & Displays : ATI - HDMI audio, with sound card
Hey, so i'm creating a new build with a Radeon 4830 Hd with a Creative Sound Blaster Audigy SE 7.1 Sound Card.
I'm going to connect this top my sony bravia HDTV, and i've heard that HD sound can be output through the HDMI cable.
Will getting a sound card affect the audio from the HDMI connection, and is there any sound card that support an Hd audio connection, that can output the many different audio forms?
Help is appreciated.
Sponsored Links
The ATi cards have a build in 7.1 sound device. This is the only sound that can be sent through the HDMI connection from the card. If you want to use the sound from your Sound Blast you will need to use HDMI for video only and then output the audio via cables to your TV.
You can change which sound device your computer uses in the control panel. I have an X-Fi XtremeGamer card that I use but it also allows me to switch to the onboard sound to my video card for HDMI.
------------------------------ Big Brother Rules with an Iron Fist
Reply to jay2tall
If you're just hooking it up to the Bravia, then stick with the HD4830.
For HD Audio you need a proper decoder (good AV receiver).
For all the features of a Creative card, plus HDAudio, then you need this;
http://www.auzentech.com/site/prod [...] ter_hd.php
But if you don't have a receiver to decode DTS-HD Master and Dolby TruHD, then there's little benefit if you're just sending it to the 2.0/2.1 audio of your TV.
------------------------------ You need a license to buy a gun, but they'll sell anyone a stamp (or internet account) - RED GREEN. GA to SK
HD Freedom: 45 5F E1 04 22 CA 29 C4 93 3F 95 05 2B 79 2A B2
Reply to TheGreatGrapeApe
Yeah, what the monkey said! haha.
Reply to jay2tall
for sound via the hdmi download the new catalist 9.1 driver from ati.
http://ati.amd.com/support/driver.html
Reply to ungrettir
There are 1022 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
  • 01:00 rolli59 won the Spy badge
