PROCESSOR - Intel Core i7 920 Nehalem 2.66GHz 4 x 256KB L2 Cache 8MB L3 Cache LGA 1366 130W Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115202
MOTHERBOARD - ASUS P6T Deluxe LGA 1366 Intel X58 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131346
MEMORY - 2 OCZ Platinum 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227381
VIDEO CARD - SAPPHIRE 100225L Radeon HD 3870 512MB 256-bit GDDR4 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102719
POWER SUPPLY - CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
HARD DRIVE - 3 Seagate Barracuda 7200.11 ST3500320AS 500GB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148288
CASE - Antec Three Hundred Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
HARD DRIVE RACK - VANTEC MRK-200ST-BK EZ Swap 3.5" SATA Removable Hard drive rack Kit, with LCD display
http://www.newegg.com/Product/Product.aspx?Item=N82E16817122105
DVD PLAYER - ASUS Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DVD-E818A3T
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135181
DVD BURNER - SAMSUNG Black 22X DVD+R 8X DVD+RW 22X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM 2MB Cache SATA DVD Burner with LightScribe
http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173
THERMAL GREASE - ARCTIC COOLING MX-2 Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186020
CASE FAN - 3 Antec 761345-75121-6 120mm Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835209006
That should be it about, already have an MX Revolution and a Saitek Eclipse 1st gen.
Screen is a Samsung 25.5" LCD
Breakdown:
Processor : Given
Motherboard : Love ASUS, great quality, great manual
Memory : Will get 12 gigs by request, iffy if the speed will be useless @ 1600, need suggestions on this. Do want the 7-7-7 cas though...
Video Card : Best bang for your buck, will need to be able to watch Blueray quality, no real gaming at all
Power Supply : Corsairs quality is amazing, 80 certified
Hard Drive : Will need for this, 1 for OS, 1 for DATA, 1 for backup of OS (Rack). I trust Seagate with quality, 32mb buffer is key
Case : have dealt with the 900 before, was a pleasure, build quality was on par, this build is more conservative
Rack : Backup of OS
DVD Player : 18x read
DVD Burner : 22x write, lightscribe
Thermal Grease : Better than #5
Fans : quality
So tell me, good?
ram will prob need changing, maybe video card, dunno.
System wont be OC'd.
64 bit Vista, of course.
Fun fact, Seagates 250gig sata 32mb buffer HD is 10 bucks more than there 500gig sata 32mb buffer HD...
Breakdown:
Processor : Given
Rack : Backup of OS
Fans : quality
So tell me, good?
