Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Using hd on monitor?
can i play pc games like counter-strike source and call of duty in a hd resolution on my monitor? my monitor uses 16:10 i have a dvi output slot from my graphics card (9800GT) and dvi in slot at the back of my monitor i think my monitor is dvi-d hdcp compatible. what kind of cable would i need? i have a hdmi cable and two adapters for it that allow the cable to be hdmi-dvi or would i need to buy a dvi-dvi cable? would it work better if i used my 37" hdtv to display games in hd resolution?
Sponsored Links
You're serious?
Check what resolution your monitor uses. If it's above 640x480 then technically it's HD.
Reply to turboflame
1. You should connect the PC to the HDTV using a DVI cable, if not then a HDMI cable.
2. As long as both video card and HDTV is HDCP capable (they should be), then either DVI or HDMI cable will display protected HD video content. HDCP does not apply to PC games.
3. Depending on your HDTV, it's resolution could be 1920 x 1080 (aka 1080p) or the lower 1368 x 768 (older standard).
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
my tv is 1080i what resolution would that be? what framerate would i be able to get in games?
Message edited by Richard_Fox on 01-28-2009 at 10:58:54 AM
Reply to Richard_Fox
There are 638 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
