Yes No
Ads
Tom's Hardware > Forum > Storage > Hard Drives > [Solved] Partition problems
Forum Storage : Hard Drives [Solved] Partition problems
Best answer from marco324.
recently i did this, [url=http://www.tomshardware.com/forum/7884-63-dual-boot-windows][/url] or for those who dont want to click, i partitioned my drive into 3 parts, my windows 7 ultimate x86, a FAT drive in which i backed up all of my files and some unallocated space to install windows 7 ultimate x64. the installation went smoothly and the backup was flawless but now im stuck. i deleted the old win 7 and FAT partitions in an attempt to regain all my loss space however i found that i could not extend the new win 7 partition to fill the void left by the other 2 leaving me with 900gb NTFS and 900gb unallocated that i couldnt reach. this didnt seem to be much of a problem as i decided that i would just shrink the NTFS to minimal size and keep all my personal files on the, newly formed from the unallocated, FAT partition. so this went flawlessly as well as the shrinking of the NTFS but now im left with this:
http://imgur.com/o2SaD.png
i cant extend the FAT partition into the unallocated space. am i left with this or is there a way to reorganize the partitions?
Message edited by pantherking on 06-29-2010 at 08:52:10 AM
Reply to pantherking
Best answer
Easeus Partition Master Home Edition free works great easy to use
http://download.cnet.com/Easeus-Pa [...] 63346.html
Reply to marco324
I can't really see your image, but FAT has a partition size limit you may be hitting.
Take a look at http://en.wikipedia.org/wiki/File_Allocation_Table
Reply to hang-the-9
Quote :
i must specify that its actually an exFAT so size is virtually limitless on a personal computer but thanks for the input! im looking at the other download now! thanks guys
EDIT: Easeua partition master worked perfectly, thank you
Message edited by pantherking on 06-29-2010 at 10:24:55 PM
There are 1471 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Connecting a Laptop Hard disk directly to Desktop (SATA)
By RetiredChief, 5 hours ago:
fantastik250 - Sata interface is only for data. Does not adjust any voltages. power is...
Best offers
Top experts
