maxtor usb external hard disk conection problem ,while transfering data
G Guest Guest Jun 29, 2010 #1 maxtor usb external hard disk conection problem ,while transfering data
J Jonmor68 Distinguished Feb 17, 2009 2,136 0 20,460 Jun 29, 2010 #2 Are you saying it was connected and transfering files when it failed, or failed to connect to pc? Failing during transfer would indicate a bad connection with cable or usb port. Try a different port and or cable.
