My system is:
Case: Lian Li PC-V1000 Plus
Motherboard: Asus A8N-SLI Deluxe
Power Supply: Thermaltake Toughpower 1000W
Processor: AMD Athlon 64 X2 Dual Core Processor 4400+
Processor Fan: ZALMAN 9500A 92mm 2 Ball CPU Cooler
Graphics Card: BFG Nvidia GeForce 9800 GTX 512MB GDDR3
Memory: CORSAIR XMS 4G 184-Pin DDR SDRAM DDR 400 (PC 3200)
Hard Drives: WD360 Raptor 40G, 2x WD2000 200G drives (raid setup?)
Sound Card: SoundBlaster X-Fi Xtreme Fidelity Sound Card
So there you have it, other than the processor fan, everything else is stock.
Any way i can upgrade this system without replacing everything and can i overclock it without burning it?
As you can guess my budget isnt such that i can just build myself a new system atm, but i can stay within a range of $200
