Yes No
Ads
Tom's Hardware > Forum > CPU & Components > CPUs > Help building a dual Xeon workstation
Forum CPU & Components : CPUs Help building a dual Xeon workstation
I've got a shopping cart going but need some advice on important decisions
I added
2x Intel Xeon E5520 Nehalem 2.26GHz LGA 1366 Quad-Core Processors
1 ASUS Z8PE-D12(ASMB4-IKVM) Dual LGA 1366 Extended ATX Server Motherboard
and OCZ Gold 12GB (6 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 Memory
So, with this mobo,
Will it take pretty much any PCI express video card? And Sound Card?
What kind of power supply do I require?
Is it essential to shop for an Extended ATX Case?
The Processor comes with no heatsink, got any ideas what to shop for?
Really need some advice before placing my order.
Thanks
Reply to InTheCIty
Take a look at this post...
http://www.tomshardware.com/forum/ [...] orse-build
Same Xeon build...will give you an idea...
Reply to gkay09
- 0 +
EDIT : Double post... :| some problem with the page not loading...so pressed refresh, resulted in double post...
Message edited by gkay09 on 03-31-2009 at 08:13:34 AM
Reply to gkay09
what are you going to be building this system for? it will give us a better idea of what hardware to recommend for you
Reply to pinaplex
- 0 +
I am following this thread because I have the same motherboard I am building up. My main concerns at this point are:
1. finding a 4U rackmount chassis for this big board-- lightweight aluminum preferred.
2. Finding a good PSU to support the dual CPUs, memory, and multiple CUDA GPUs
3. Finding a liquid cooling system. I have never used liquid cooling to this point.
Please share your findings with me!
Reply to jazzop
Have this company build your workstation computer and they have a dual xeon with water cooling: www.titanuscomputers.com
Reply to suchimi5410
There are 1473 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Help Understaing Hardware Montior readings
By DJDeCiBeL, 3 hours ago:
 I agree with that assessment, and with the temps in that range, it's nothing to...
Best offers
Top experts
