Having trouble with my first boot on this new built I just put together. I see a blue LED light in the front panel and that’s all the activity I get. No boot/shut down or initial fans spin…NADA!
COOLER MASTER RC-690
GIGABYTE GA-EP45-UD3P
Intel Core 2 Quad Q6600
XIGMATEK HDT-S1283
OCZ Reaper HPC Edition 4GB (2 x 2GB)
SAPPHIRE Radeon HD 4870 512MB
Western Digital Caviar Black 640GB
Samsung DVD burner with LightScribe -OEM
CORSAIR 650TX
I pretty sure I connected everything correctly (maybe not since it won’t boot). Had the brass spacers before I lay down the mobo. Front panel connections are correct (white negative & colors positive). Connected the 24pin and 2x4 12v to the mobo.
Any suggestion short of taking everything out and putting it all back? Any help would be appreciated.
Will
XIGMATEK HDT-S1283
CORSAIR 650TX
Will
