Hi, this is my first post so I hope I'm doing this right. I just purchased an ASUS P5KPL-CM motherboard that supposedly can achieve a front side bus speed of 1600Mhz through overclocking, but I'm not sure how that is achieved.
The motherboard has DDR2 1066 memory and the Intel Core 2 Duo 6600 processor has a front side bus speed of 1066Mhz. The bios allows me to select a DRAM Frequency between 667Mhz, 800Mhz, and 1067Mhz, I believe.
When I went into the BIOS and changed the DRAM Frequency setting from 800Mhz to 1067Mhz the computer became very noticably faster. My question is this... My CPU has a bus speed of 1066Mhz, but assuming I had a faster CPU with a 1333Mhz bus speed, my DRAM Frequency choices in BIOS would then be 667, 800, 1067, and probably 1333 or 1334. How would I get it to 1600Mhz?
This has really got me puzzled. Hopefully there's a OC guru our there that can explain this to me. Thanks!
