Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > GTX 285 questions. Plz help!
Forum Graphic & Displays : Graphics Cards - GTX 285 questions. Plz help!
My system
: CPU E6850 3GHZ, Ram 4 GB 1066Mhz, mobo Asus P5KC, PSU Zalman 600W, Samsung 22'',windows xp SP2.
I will sell my vga card XFX GTX 260 xxx edition for 220€, to buy a GTX 285. My question is: My mobo supports PCI-E 1 and the new card is PCI-E 2. Will i have problem with the bandwith? I mean half of the power of the card will be lost?
P.S. 1 sorry for my poor english
P.S. 2 am i see big difference between the 2 cards. The upgrade will cost me 100€.
P.S. 3 My PSU Zalman 600W is enough for this card?
Thank you, i am waiting your opinions!
Sponsored Links
A) Its ok most of us cant be arsed to spell properly.
B) You'll see a marginal increase but i dont think its worth a 100euros.
C) Your Psu fine to handle it.
D) Its up to you and i wish you the best of luck :P
------------------------------ If you're falling off a cliff you might as well try to fly, you don't have much to lose...
BUILDING!!~ i7 920/GIGABYTE GA-EX58-UD5/3GB TripChan DDR3/Sony DVD-DL writer/ HDD500GB/HD4870 1GB/A+ Case/ANTEC500Earthwatts
Reply to OmegaStalker
^+1. It's definitely not worth 100€.
Reply to Avenger_K
try from 260 to 295GTX
Reply to Milos-stancene
- 0 +
His GTX260 is already well overclocked, so it`d be more like going from a GTX280 to a GTX285...Totally pointless waste of money.
Reply to coozie7
both cards are PCI-E 2.0 standard and compatible with 1.0 if you are able to handle GTX260 then might as well go with the rest get the GTX 295
------------------------------ Intel Pentium 4 630 3.0Ghz Shuttle XPC SB81P(intel 915G)
Patriot Dual Channel 2GB DDR400: Raid0 640GB 2pc WD3200AAJS
Powercolor ATI Radeon HD3870 PCS 512MB DDR4
http://valid.x86-secret.com/cache/banner/414710.png
Reply to goonting
you got 1680x1050 resolution? your GTX260 its one supercharge card for this resolution
Reply to goonting
Not really....I have a eVGA GTX260 216 55nm at 740/1080 and Crysis gets a solid 40fps at 1680x1050 so it's not really overkill per say, but he wont' see any major increases until he goes for a GTX295.
Reply to brendano257
Well i play at 1680X1050 all in very high details and i have over 45 fps. Only in Crysis i get 37 fps.
The reason i post this thread is if my mobo will bottleneck my card because its PCI-E 1 and the card is PCI-E 2.
Also i am only give 100€ for this upgrade.
From your answers maybe i will keep my XFX GTX 260 xxx vga card.
P.S. sorry for my poor english
Reply to Aristhewargod13
There are 1241 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
