Amd x2 7750 Bus speed 0mhz??
iamsven
hi guys. i have a problem. i recently got a kuma 7750 cpu to replace my old cpu. when i open easy tuner 6 the clock speed for BUS its 0.00mhz. I dont know why that is can anyone help me?
GA-MA78GM-US2H . bios version F3
memory: 4gb of ddr 2 sdram....
frequency for each in the timings table
400/333/266
cas#Latency
6/5/4
Ras# CAS#
6/5/4
RAS# to Precharge
6/5/4
Tras
18/15/12
any other information needed?
i didnt touch anything else. i tried to update the bios tho with @bios
is this normal or what should i do. i really need some help. srry if this is in the wrong category
stoner133
583
The board was given support for the 7750 with BIOS F2 so running the newer F3 isn't a problem. I suggest you look at the Gigabyte web site for board utilitys, there you will se that Easy Tuner 6 is only supported by Intel chipset motherboards and not your AMD chipset. Your going to have to uninstall Easy Tuner 6 and then download and install Easy Tuner 5.
