I'm new here. I discovered this website after going through New Egg's help section. I've already gone through a number of 'sticky's '..... and I have now devised my own homebuilt system. Before I go ahead and make an order, I would really appreciate some input on my proposed build.
The Objective: Build at system that can handle most media related tasks. Also I would like to do a little number crunching (matlap, mathcad, excel). Multi-tasking is a big thing for me, as I intend on converting videos..and possibly running some software like matlab or mathcad. I do a lot of computational work...so its nice to have the power to do both. I plan on running Windows XP.
Here is my Proposed System:
Computer Case:
NZXT TEMPEST Crafted Series CS-NT-TEM-B Black Steel/Plastic
ok it looks good but i would get like a radeon 4850 or 4870 because (they are much better) and you can use that thing that ati has for converting videos using the videocard which is much faster than a cpu convert. and you might want a better PSU (for the future if you want to upgrade)
We aren't big on AMD right now, around here.... for many good reasons. if you were going to build an AMD rig today, you would do so with the hope that the new CPUs from AMD, due out "soon," will actually live up to the hype and will indeed be compatible with that AM2+ MB. If so, you would want one of those and NOT a 9950, which is equivalent in speed and price to a midrange Intel quad core (Q6600).
Beyond that:
- You are buying a rather pricey (but nice) crossfire board. It's a bit out of whack with the rest of the build. You could save money there that you need elsewhere.
- You are putting an Nvidia card on a crossfire board. You should put a card capable of crossfire on it. A 4670 would be as fast or faster than that 8800GTS, for around the same price. A 4830 would be faster for a bit more.
- The PSU would not be one I would trust. Thermaltake has a bad habit of sending out one model for reviews and then marketing a very similar looking model with a different part number. You pretty much get what you pay for with PSUs... there are a few exceptions to that rule and we're all over them here
- The Reapers are OK, but you would be better off just paying 35 bucks up front for some good 800Mhz RAM and forgetting the rebate.
- You would need more than paste to cool that 9950 BE - it does not come with a cooler.
In my signature you'll find a guide, which covers any reasoning I did not include. Also you'll see a list of recommended parts.
I don't know how much of an impact the GPU has on video encoding, if boop334 is right and it does have an impact, it would be worth it to switch to at least a 4830 (in your price range) or the 4850 (unless the encoding gain is massive, the 4870 is overkill IMO). Anyone has benchmarks for that?
As Proximon suggested, you might want to consider a Q6600, it's only 20$ more than the CPU you chose, but it comes with a cooler. When looking at benchmarks, both CPU's perform about the same anyway.
------------------------------The capacity to learn is a gift; The ability to learn is a skill; The willingness to learn is a choice. - Rebec of Ginaz
Reply to Zenthar
Thanks guys. I'm going to the suggestions that have been directed to my post thus far, and do a little homework. My budget is around 900. I figure I can always buy a new new monitor in the future, and I'm not interested in Vista OS as of yet. I don't do any hardcore gaming, as I mainly use my xbox for that. Maybe one day lol... but for now, like I said, videos...converting videos...syncing my xbox...liking my PC to my HDTV...number crunching...nothing spectacular here....
Thanks again! Maybe I'll reconsider an alternative CPU...
if i were you i would get vista, unless it just doesnt work for what you want, but i use it and would never go back to xp for anything! It is so much faster!
Thanks buddy. I'm not quite sure yet about Vista OS... from what I've read, isn't there a new version of Windows coming out? Isn't it called....Windows 7? I think I'll wait...
Boop you are the only person on the planet who cant getVista to run significantly faster than Xp would with half the RAM .
With Windows 7 here this year Im happy to wait
Very little point using a gaming gfx card from 2-3 generations ago of encoding . If you want to game then a 4850 and if you dont then a 4670 or 4830 which should help with video encoding using ATI's version of ' cuda
Boop you are the only person on the planet who cant getVista to run significantly faster than Xp would with half the RAM . This did not make any sense
Note that I have increased the HD to a 640GB and it includes a Q9550 CPU.
Also included is some after market CPU cooling. With such a well-cooled case you might as well do a moderate overclock on the CPU.
