Tom's Hardware > Forum > Graphic & Displays > ATI > Problem with Ati Radeon X1950 Pro
Here's what happened. I built my computer about 2 years ago with the following specs:
450W Xion PSU (came with case)
Asus p5b mobo
Western Digital HDD
Sapphire X1950 Pro
Bgears B-enspirer7.1 audio
ati 650 pro Tv tuner
Since then I have made some minor upgrades such as additional hard drives and dvd drives. It's been running great and has been over 3 months since I have made any changes to the internal hardware. What happened was that I was setting up a dual-boot of vista and Windows 7 and trying to figure out the driver and Catalyst Control center on Windows 7 and I tried restarting the computer after many unsuccesful attempts at fixing the software problem, and when the comp tried to reboot the system speaker gave one long beep followed by 3 short beeps. after searching for what this means, as it is not in the manual for the mobo, I determined that it meant a problem with the video card. I unplugged everything from the computer, HDDs usb accessories, dvd drives, pci cards, nothing. still got the same beeping problem. I don't see anything on the monitors. Here's the weird part, if I unplug the vid card 4 or 6, I can't remember right now, pin connector the computer boots as normal, just without sending a signal to the monitor, otherwise it just keeps trying to restart over and over again while incessently beeping in the same pattern.
I think that's all, Any help would be greatly appreciated. I'm so frustrated with my computer right now because without the video, it's essentially worthless.
Sponsored Links
Check the memory. Put in 1 stick at a time.
Try different memory if you can.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
There are 1152 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
