I would like to water cool my phenom 2 940. Whats the "best bang for buck" kit out there? If i decided to build my own kit. Whats the "best bang for buck" brands? Thanks for your help... new to site
To be honest, unless you're prepared to spend over $150~$200 bucks on water cooling, its probably better to stick with air cooling. Generally speaking a $150 kit can perform up to a Thermalright Ultra-120 (TRUE).
However, if you still insist on going for water, there are some beginners' kits you can look at.
Its probably better to stick with 2x120 rad (radiators that can fit at least 2 fans), or else just go with air cooling.
------------------------------Intel will not take the top spot, or probably the top 3 spot back for the forseeable future. Not even with 32nm and more cores will intel be able to beat Jaguar. - JennyH the AMDiot, Nov 2009
Reply to yomamafor1
Personnaly I build my own, every kit I have seen (besides most Swiftech kits) are garbage. http://www.frozencpu.com/products/ [...] 30c321s818 $400, You will need a new mount for the CPU waterblock (it's cheap, and on the same site)
I built my own from parts on Danger Den, and I got the swift tech water block from the egg. Do not get a thermaltake water flow meter, they are a waste of $30 and they leak right of the bat. I am running mine with out a flow meter now, and have it set up with a 655 swift tech pump, kinda over kill, but if I want to include my 4870's in the loop I can. I use tygon 1/2 lines with Ultra fluid XP+ non conductive fluid. I have a auto trans radiator I got from the auto parts store, 12"x12" and a 230 mm fan to cool it. Love this set up, and it keeps my Phenom II 940 overclocked a 3.6ghz stable at 32c-40c at all times.
A Thermaltake Armor LCS VE2000 WSA is the best for you. Cheap, plug & play and designed for AM2+ processors like the 940. It would be slightly more difficult with an AM3 processor ;-)
