Hello,
Today I overclocked my Powercolor 5870 pcs+ to 960/1235, the normal clocks for the card are 875/1225, which is a factory oc.
After my overclock I decided to run a benchmark to see if there was any difference, I went for the dirt 2 benchmark and ran it. TO my surprise the average and minimum fps were almost exactly the same, they didn't even differ by 1 fps.
With a core overclock at nearly 100Mhz, shouldn't I be seeing at least a 3-5fps gain? I'm new to overclocking though, so I'm not sure. Any suggestions to what could be causing this, bottleneck maybe? Or does the memory oc need to be higher in order to see gains?
