No. I actually wanted to install it the way you said, but when I pointed it towards the rear, the PSU would be in the way. No room, small case. What can I do as it is to better it? ?And the bottom Drive bay is covered by some plastic design. If I just open up the place up front where you marked the 120mm, will it improve airflow? And my PSU is on top.
------------------------------Intel Core 2 Quad Q6600 @ 2.4 | Thermalright Ultima 90 120mm fan | Intel DG31PR | 4 GB DDR2 @ 800MHz | HD 4850 512 GDDR3 | Corsair VX450 | Samsung 22x DVD RW | Windows Vista HP 32-bit/ Windows 7 64-bit dual boot | Samsung SyncMaster 19" LCD VGA 920NW |
Reply to rags_20
