Help! Power problems
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Help! Power problems
I recently bought a gigabyte ux58-ud3r board which has the 2x4 12v connector in addition to the 24 with an i7 920 chip. I pulled my old PSU which is 500w i thought would be plenty, but it doesn't have the 2x4 connection. it seemed to power up, but I never got a display or bios. They made it seem optional, but is that 2x4 12v connector necessary in order to start a comp with an i7 chip? Very new at this, just wanted to save some money and learn to build my own. oh yeah, ram is 6gb (3x2) ddr3 1280.
Sponsored Links
Definately need the 12v MB connector to supply power to the CPU. The 4pin from the PSU should be sufficient. A four pin to eight pin adapter would provide a better ground, but not anymore than 12v to the CPU. Try the system with the minimum needed to get to BIOS, CPU/HSF, 1 DIMM RAM in slot 1, video card. Unplug everything else HD, case fans, optical drives, etc.
Reply to badge
- 0 +
The mobo needs at least a 4 pin cpu power. If the psu has the 8 pin, then that is a bonus as mentioned above. But at minimum it needs the 4 pin cpu power.
------------------------------ CM HAF 932 - 300GB Velociraptor
GIGABYTE GA-EP45T-DS3R
E8500 - Sapphire 1Gb 4850
4G DDR3 OCZ Reaper 1333
Reply to aford10
just tried it with the 4pin hooked to the 2x4 slot, 1 module of ram in slot1 and graphics hooked up, still seems to power up but no display/bios- not sure what to do maybe board or cpu is bad? this might be a dumb question as well, but i put in the 9 spacers, rested mb on top then put washer/screw to attach, so there couldn't be a short anywhere?
Reply to jbwoolery
- 0 +
You don't need spacers. Try it with the mobo outside the case on a piece of cardboard.
Reply to aford10
- 1 +
If you power on and stay powered on there is no short to the MB. Try the 4pin in the other side of the MB header 8pin connector. You have a quad, so it may need a better ground to provide the proper 12v power to the processor. The 'no power' to the processor (forget to connect the 4/8 pin 12v power from PSU to CPU) is a classic.
Reply to badge
As pointed out, 4 Pin should work, 8 Pin connection should only be required when pulling more than 120 W, Which a stock i7 920 should be below (do not confuse with max TDP). I think you will find that all 4 +12V sockets on the MB are tied together and all 4 grn sockets are tied together.
badge - Not positive, but I think the connection is keyed to that the PSU connector should only go in one position ( except for gorrillia man)
Added
you are correct in that it could fit top or bottem Halve as plug is shaved at both corners
OP - MAKE SURE that you put the 4 Pin in correctly (You currently have, as incorrect would fry psu and/or MB.
Message edited by RetiredChief on 04-03-2009 at 08:48:38 PM
Reply to RetiredChief
- 0 +
It's hard to plug in the 4 pin cpu power wrong. The connector and port are shaped specifically to avoid that. There is also usually a clip on the connector that hooks onto a groove on the mobo port.
Reply to aford10
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Help! Power problems
There are 980 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
