Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Is my old power supply good enough for my new stuff?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Is my old power supply good enough for my new stuff?
Here my power supply right now:
http://www.newegg.ca/Product/Produ [...] 6817103515
I'm getting this new graphic card:
http://www.newegg.ca/Product/Produ [...] -_-text-_-
and this motherboard :
So, i would like to know if i need a better power supply and if so, what would you suggest to me? (not over 100$ plz!)
Thx
Sponsored Links
Hi, you definatley need a better PSU. Dont get a non brand one like a Sparkle. Go for somthing like, http://www.newegg.ca/Product/Produ [...] 6817341010
Reply to tobensg
No No No NOO
Don't even point that PSU in the direction of that card.
I take it you have a Core 2 Duo or Quad to go with it. Even though your system will probably use under 350W (if you measured it from the wall it would probably be like 310W), I wouldn't really trust that PSU to handle even 80% of it's stated output without burning out. There is a reason that at least a 550W unit is recommended for a single GTX260. Anyway this is a good PSU that should suite your purposes as it's very efficient and won't break the bank
Antec earthwatts EA500 500W $79.99
http://www.newegg.com/Product/Prod [...] 6817371007
or if you really wanted a 550W PSU
Antec BP550 Plus 550W $79.99
http://www.newegg.com/Product/Prod [...] 6817371016
or
CORSAIR CMPSU-550VX 550W $89.99
http://www.newegg.com/Product/Prod [...] 6817139004
I'd take the Antec Earthwatts unit though as they are high quality and very efficient.
------------------------------ Playing X-Men Origins: Wolverine Athlon 64 X2 5000+ @3.24 Brisbane | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
Corsair, PC Power & Cooling, and Seasonic all have a reputation for high quality power supplies that are very stable and reliable. They consistently earn high marks in technical reviews and comparisons. Those three psu brands are the ones most often recommended by veteran posters at this forum.
Please list the rest of your pc components
Are you a hardcore gamer?
Are you into overclocking?
Are you planning on using multiple video cards in SLI or Crossfire mode?
It's difficult to make a specific recommendation without the additional information.
Reply to JohnnyLucky
Intel Pentium E5200 Wolfdale 2.5GHz 2MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
This is my new processor. i'm gonna check all those PSU , thx! didn't know it would matter.
Reply to Primusave
gonna start over ... here's my stuff :
ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler - Retail
Seagate Barracuda 7200.11 ST31000333AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s Hard Drive - OEM
EVGA 896-P3-1255-AR GeForce GTX 260 Core 216 896MB 448-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
GIGABYTE GA-G31M-ES2L LGA 775 Intel G31 Micro ATX Intel Motherboard - Retail
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1000 (PC2 8000) Dual Channel Kit Desktop Memory - Retail
About the other questions, i'm a gamer but i'm not into overclocking. I'm gonna use only one Graphic card.
Reply to Primusave
The Corsair VX550 that megamannx00 mentioned would be a good choice for you. It has a single large +12 volt rail rated at 41 amps. It can definitely handle your system if you are not going to overclock or not going to use multiple video cards.
The Antec Earthwatts 500 is another good choice. It too has earned favorable reviews. If you decide to get this one make sure it is the new version. Check the specifications before buying. The old version had mutiple +12 volt rails rated at 17.5 amps each. The new version has mutiple +12 volt rails rated at 22 amps each. The new version also has better internal parts.
rofl @megamanx00. The Sparkle would probably live up to its name, however briefly, if connected to that GPU. The Antec Earthwatts 500 would be a great choice.
No need for DDR2-1000. Get this DDR2-800: http://www.newegg.ca/Product/Produ [...] 6820146731
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - $48 after $10 MIR. It isn't the cheapest, but it is very good RAM.
If you are not going to overclock, you won't like the E5200. It is a mutt at stock. You won't need an aftermarket cooler if you don't overclock. Take the money from that CPU plus the cooler, add the change out of your couch, and get an e7400 instead: http://www.newegg.ca/Product/Produ [...] 6819115206
The newer Seagate drives have spawned a lot of horror stories. I wouldn't buy one. Get this 750GB WD instead: http://www.newegg.ca/Product/Produ [...] 6822136283
You might consider an ATI HD4870. Same tier on Cleeve's performance chart, but ~$30 cheaper.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
About other parts than the PSU , it's too late, already got them (still waiting for the shipping of the RAM... it's on its way). I already received the 1TB harddrive and i learned after buying it that it had bad reviews , so i'll deal with it and hope it will last.
I might consider overclocking it in a far future lol since you say it's kinda bad as it it right now. Still got to learn a lot about overclocking before i test it out though. I'm gonna go with one of the 3 products you guys mention ealier , the 2 antec models or the Corsair one.
Thx!
Reply to Primusave
I understand there may be a firmware update from Seagate that will fix the drive. There should be information and the necessary tools on their site.
Reply to jtt283
If you decide to update the firmware though, be careful and make sure it is exactly the right firmware for your drive. I've heard of people bricking their drives with the wrong firmware.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
You could certainly do a lot worse than Sparkle, which is a division of FSP who at one time were one of the top PSU makers. They used to be the OEM for the PC P&C Silencer. I would not be surprised if the PSU could run this system, but a new PSU is definitely a good idea.
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
There are 1285 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
