Air flow when front fan is not available
Hi
I got old case(have no idea what brand) and it have no perforated front, its just solid plastic.
The only way the air could go in is the ~2 cm gap that is actually not at the front, but bottom. Its very close to the front though so some poor air it could take...
There is position for 80/92 fan inside, but I am just pessimistic with the idea when I see that it can't get any real airflow.
Even back don't have 120 but only 92. Fan I put there is set for intake because I see no other way for it to get fresh cold air.
Only way that is pushing hot air out is probably through PSU :(
CPU: Athlon II X3 (unlocked 4th core)
PSU: 400W Seasonic
CPU heatsink is for now just box one
Currently I have it set open, without sidepanel, while I am testing stuff.
Temperatures without load are ~35 °C with fans set to 15% by speedfan.
but if I put sidepanel there it jumps to ~43 °C
I hate it...
So question is anyone dealt with such pc case?
What are my options?
More about : air flow front fan
Quote:
Only option really is to buy a new case. There's a Rosewill Destroyer case on Newegg with i think 5 fans for 49.99
I would sooner cut a holes in sidepanel for 120 fan or 2x120 than buy new case...
buying new *** is like being defeated by that stupid case...
jerfle said:
If it was 60 C I would worry. 43 C is nothing to worry about.
Its not CPU but south bridge I am worried about... I can't hold finger on it and review of my board ASUS M4A785TD-V EVO mentioned that it could get quite hot on that passive. Thats why I am concerned with overall airflow.
I'll test how it will go with front/back even if it does not have ideal vent holes.
Related ressources
Bump on the hacking cases approach :)
Mark the four screwholes for the 120mm, drill them, then either cut a hole out for the fan or drill a gazillion little holes, if you want to make it tidy, get a grill or filter that mounts on the outside of the case to hide them a bit :)
Moto
There will be no cutting for now :)
I seriously underestimate the power of exhaust fan. I never would imagine such a results, I always thought its logical that blowing cool air inside would be better, but then I browse around here and found thread where people voted which one is more important, "exhaust>intake" won.
So I tried and here are the results.
Prime95 test
closed case, back fan as intake, none frontfan
20min 30min
cpu 61°C 63°C
mobo 47°C 47°C
30 minutes of idle, after the test
cpu 38°C
mobo 40°C
closed case, back fan exhaust, front fan intake
20min 30min
cpu 56°C 57°C
mobo 29°C 29°C
After the test, right now its cpu 35°C and mobo 30°C
The motherboard temperature is kinda puzzling. My guess is that prime does not put any load on it, or something. And that high temperature it got from first measurement is from accumulated hot air? seriously dunno...
It got hotter with a movie more than prime(I am using onboard graphic card for now, so aero in win7 might be the reason)
Anyway results are really surprising to me. Either the air from front gets there much easier than I would thought, or its the pure power of exhaust fan. Can probably test if I disconnect front one, but thats for another time.
Overclocking Expert
I was about to chime in with putting that rear fan , BACK to exhaust. That is the probably the most important fan, next is the top exhaust. The side fans, meh. Its easier and effective to get a flow going front low, rear/top high. It how heat works (obvious), it rises.
Ask the community
