Ok, basically I've bought a new pc (not a pre built one, just components) as of last wednesday, me and my flatmates assembled it and got it all running but the cpu was severely overheating so we stopped using it and got a new cpu heatsink and thermal compound, whereupon we disassembled and reassembled it in order to install them.
After doing this the computer starts up but no display appears on the monitor. When using a vga cable it says check signal cable on the monitor, and when using dvi it does not, but either way there is no display. We have replaced both the graphics card and the motherboard and still it is not working. We don't think either of the new components are damaged although it is an unlikely possibility. We know the monitor works as we have tested it on another pc.
The hard drive still has the drivers for the old graphics card on it as we have obviously been unable to wipe it due to having no display, but I do not know if this will make a difference. Does anyone have any ideas on what it could possibly be?
So what it wont display at all no boot screen even ? Getting around the drivers would be simple if they were the cause by booting into safe mode.
You do have all the power leads connected to the Graphics card and other things ?
Its easy to leave something off when you are trouble shooting.
All the power cables are connected correctly, and there is no display at all. Ie there is nothing when the computer starts up, no boot screen, no loading windows, no anything.
Could you state what type of Motherboard it is / RAM / CPU.
If there is a CPU issue the pc will power on however you will not be able to see anything on the PC because basically the CPU is not processing anything.
I would re seat the CPU, and ensure it is installed in the right orientation.
Then if it is a 4 channel DDR memory you have on the Mobo, make sure that you are using the correct slot for a sincle strip / or the dual channel config for 2 strips of memory.
Hope this helps.
------------------------------Armor LCS Full Tower ¦Asus P6T Deluxe OC Edition¦Core i7 920 @3.8 GHZ¦EK CPU WaterBlock¦Corsair Dominator 1600 Mhz 3 x 2GB¦Asus 4870 x2 2GB¦Stock Triple Fans¦ XFI Fatality Platinum¦ Sony Bluray Drive¦ Samsung 1 TB,Hitachi 500 GB HD¦ Vista x64 SP1¦
Reply to ztransporter
The motherboard is a P5QL Pro, the RAM 4 gb of OCZ, the cpu an E8400 and the graphics card a 9800 GT. The processor has been reseated twice in two different motherboads to no avail.
