Tom's Hardware > Forum > Graphic & Displays > ATI > ATI Radeon HD 4850 idle temps creeping up
Forum Graphic & Displays : ATI - ATI Radeon HD 4850 idle temps creeping up
Hello,
I built a new PC around September of last year and got the VGA SAPPHIRE 100242L HD4850 512M RT from Newegg. I know the card runs hot, but here 6 months later I find the idle temp on my card going higher and higher.
First it started idling at 80C, which I was fine with, I know the card runs hot. But progressively the idle temp kept going up, 81, 82, 83, etc and now the card is idling at 85-86C after 6 months; while I am just in Windows, not even playing any games.
I opened the case and checked for dust on the fan etc, and found almost no dust or anything like this so I don't think that is the problem.
Is my card defective, and if not why does my idle temp keep going up over time?
Thanks for any help and advice.
Sponsored Links
wow... My guess is that there's something wrong with the fan, which leads to high idling temps. the card's fan is a factory one, so i recommend getting an aftermarket one.
------------------------------ Needs a job...
Reply to romulus47plus1
There are 776 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
