Tom's Hardware > Forum > Homebuilt Systems > New System Build > Q6600 build, need some advice on the parts (Urgent)
Forum Homebuilt Systems : New System Build - Q6600 build, need some advice on the parts (Urgent)
Hey everyone,
I was reading alot before I finally got these parts together but still its hard to decide about some of them..so I list them, I'm waiting good/bad comments, anything helpful.
INTEL CORE 2 QUAD CORE Q6600 2.40 GHZ LGA775 - 1066 FSB - BOX
GEIL GB22GB6400C4DC DDR2 2GB (2X1GB) BLACK DRAGON PC6400 800MHZ DUAL CHANNEL KIT
COOLERMASTER RS-520 REALPOWER M520 520W
COOLERMASTER RC-532 CENTURION 532 BLACK - case
GIGABYTE GA-EP31-DS3L
XFX GEFORCE 9800GTX+ CUDA 512MB PVT98WYDQ PCI-E RETAIL
SAMSUNG DVD-RW SH-S223F BLACK BULK
WESTERN DIGITAL WD6401AALS 640GB CAVIAR BLACK SATA2
I know i P35 gigabyte mb is better, but i just cant order (the shop where i order from doesnt have, only asrock/ecs with p35) and i thought P31 is just the same (i dont need ddr3). about the ram any idea, or especially what i cant decide is the psu (i think this one should be ok), and the big question is with the vga card, as its kinda expensive and dunno really if the difference between a 9800gt and gtx is high enough.
Thanks in advance,
PS: Would need urgent replies.
Sponsored Links
It's like a post from the past :)
You need a P45 motherboard. Or P43.
The power supply needs to be better.
You should get a 4 GB memory kit.
A 9800GTX+ is not a good deal. They are overpriced for the performance they give.
See my guide in my sig.
------------------------------ My Guide to choosing parts
A big list of recommended parts
Troubleshooting Guide w/links
Reply to Proximon
Hi, easiest if i give you the link where i order the stuff from so you can choose. dunno if there's an english version but its easy to find what u need.
http://www.e-shop.gr/PER_motherboards.phtml
http://www.e-shop.gr/PER_mem.phtml
http://www.e-shop.gr/PER_video_cards.phtml
http://www.e-shop.gr/PER_psu.phtml
these are the links. whats the main difference between a p45 and p31. can win xp recognize 4gb ram, or at least can it start with 4gb? vista will be not used, i think, it will be never used. 9800gtx or gt this i couldnt decide aswell, maybe buffing up some other parts and going with a cheaper vga would be the solution.
Im waiting ur reply.
Thanks
Reply to OZSA
Win XP will work with 4GB of RAM, yes. It will only be able to use 3.5 GB (I'm assuming you meant XP Pro 32-bit), but that's OK.
Reply to aevm
Ok, then choose a 4gb one:)
Reply to OZSA
This one looks good, for example:
KINGSTON KHX6400D2K2/4G DDR2 4GB (2X2GB) PC6400 800MHZ HYPERX DUAL CHANNEL KIT
DDR2 PC2-6400 240-pin
http://www.e-shop.gr/show_per.phtml?id=PER.553910
You need something labeled DDR2 (not DDR3), with 240 pins (not 200), and not labeled MAC.
Reply to aevm
Quote :
any decision on these yet? if u got time please check out the links i posted
Reply to OZSA
btw, the cas latency, and those numbers 5-5-5-15 on the ram, what they mean? (shortly)
Reply to OZSA
The 5-5-5-15 are timings. The first one is the CAS latency. Don't worry about them. RAM with smaller numbers there will overclock better, but it will cost more. Since you needed to ask this question, it's safe to assume you're not into overclocking and you might as well save your money.
Way more details than you really need can be found here:
http://en.wikipedia.org/wiki/CAS_latency
Reply to aevm
i will not overclock i think, even if i will do, it wont mean to make a q6600 to 3.8ghz or something..maybe to like 3g...3.2g max, but its atm leave oc. i just want a good psu,mb,vga..
Reply to OZSA
GA-EP45-UD3R or P5Q
http://www.e-shop.gr/show_per.phtml?id=PER.526784
http://www.e-shop.gr/show_per.phtml?id=PER.522630
SEASONIC M12II-500 80 PLUS 500W
http://www.e-shop.gr/show_per.phtml?id=PER.700115
Very hard to find a good PSU on that site, especially if you have no clue about Greek like me. No Antec, no PC Power & Cooling, no Corsair, etc. Enermax and Seasonic are there with a few models. I'm guessing the brands popular in Greece and those popular in North America are totally different.
Prioximon is right about the 9800GTX+ being overpriced, especially on that site. 196 euros for a 9800GTX+ makes no sense when a HD 4850 is faster and sells for 131 euros, or a HD 4870 is way faster and sells for 208 euros.
http://www.e-shop.gr/show_per.phtml?id=PER.510675
http://www.e-shop.gr/show_per.phtml?id=PER.510674
Reply to aevm
the mainboards are nice but they are more then double of p31, is there really such difference between them? things like firewire i wont use ever in my life, or sli, or whatever extra nonsense **** they have.
the psu is nice too, but why is it double of the coolermaster? cm sux that badly or its just seasonic a big name out there ? about the ati cards i dunno, had some before and always had driver issues, nonstop. btw, do this has pixel shader 4, and all the new useless features that the new games ask ? dx10 support?
Reply to OZSA
Im selling my pc if your interested. =D
Reply to invisik
The MBs I listed don't have either SLi or Crossfire, they're for one video card only. OK, I'll try to find something cheaper.
CoolerMaster is one of the worst PSU manufacturers, while Seasonic is one of the best. OK, CoolerMaster makes decent stuff these days in the 850W+ range, but those smaller ones are risky. Let's try this: you search that site and get a page that lists all the PSUs, sorted by price. Give me the URL, then I'll look at it and try to find something decent and not very expensive. I tried to do that but I got lost in the Greek.
DX10 is supported by all cards like 8800, 9800, HD 38xx, HD 48xx. LOL at driver issues, absolutely. I have owned both ATi and nVidia cards and always had driver issues. My current card is an 8800GTX and it was a nightmare for the first 6 months until they fixed the drivers. Anyway, the HD 4850 and HD 4870 and 9800GTX+ are all selling well and drivers are pretty good now, thanks to all the people testing them.
Reply to aevm
im searching after brand, and keep going to the next page, basically not more then you do i guess.. i have to make the part setup untill tomorrow about 2-3pm (gmt+2)
about the coolermaster psu i didnt know its one of the worse, as i never bought any psu unit in my life, just standard with the case. it looks like the hd4850 is ok, gonna get that one, asus mb looks ok, im checking the ram again, u sure that kingston gonna be good ? now the psu is the question. case doesnt matter i hope. cpu must be ok, hdd is, maybe a decent dvd writer that u tested these days would be a good advice.. hmm check check..what else? any extra cooling a q6600 needs or the stock one is ok? thanks for ur time aevm. u got a beer :D
Reply to OZSA
Well done aevm.
OZSA, at all cost, except maybe the PSU, get a P35 or better and RAM with DDR2 800 at 1.8V. The timings are less important, you will never go over 400 FSB.
Message edited by Zorg on 01-09-2009 at 07:12:19 AM
Reply to Zorg
This Samsung SH-S223F DVD writer is pretty good. Very popular in the USA.
http://www.e-shop.gr/sort_search.p [...] 3F&x=0&y=0
I found a decent PSU for 72 euros (not 119 like that Seasonic).
AGAN TG500-U33II SUPERROCK 500W
http://www.e-shop.gr/show_per.phtml?id=PER.700686
BTW, for anybody who would like to help in this thread, go here:
http://www.e-shop.gr/PER_pc_config_desktop.phtml
This way you get to see what's available, even if you don't speak Greek.
Reply to aevm
OK, if you don't want that Kingston RAM, how about this one:
GeIL Black Dragon 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
http://www.e-shop.gr/show_per.phtml?id=PER.553026
It's also available in the USA and got good reviews there:
http://www.newegg.com/Product/Prod [...] GB6400C5DC
Reply to aevm
Sorry aevm, my brain is full today :p
You seem to be doing well though :)
Reply to Proximon
I just ordered what you said there, gonna see how its working next week, thanks guys
Reply to OZSA
Good luck with the build! Let us know how it works.
Reply to aevm
There are 838 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
