Currently i have a stock hsf but i just ordered a Arctic Cooling Freezer 64 Pro.
under normal load movie web browsing its about 41-45c which seems high to me.
I don't know where to start at all i do have amd overdrive compatible mb with acc
motherboard temp is 39c currently
individual cpus between 37-44c
ASRock M3A785FXH/ 128
Arctic Pro 64
KEEP IN MIND DONT HAVE AFTER MARKET COOLER YET
Kingston KVR1333D3N9K2/4G DDR3-1333 4GB
Amd ii 630
Ive read its better for me to overclock the fsb not the multiplier (cant oc that anyways not BE) and drop the multiplier down cause its better for "SPeeD", "Loading" and "File Transfers"
btw i am a complete noob at overclocking i have never overclocked anything.
edit- Everst ultimate thinks my computer is a phenom :/
Okay well i have upped the fsb
on test 1 i got moved the fsb from 200 to 210 here are the results and so on
in bios.
I dont see a option to just change the cpu frequency from 200 its grayed out and in a drop down from a option called Overclock mode and its set to optimized. However there is 3 other settings Auto, Cpu,pcie sync and Cpu,pcie async
Auto wont let me change anything.
Cpu pcie sync only lets me change the frequency(fsb)
Cpu pcie asyc lets me change frequency and pcie frequency aswell as enable or disable spread spectrum, advanced clock calibration and cpu active core control im gonna go with just "cpu pcie sync" and change to 210.
update1-
orginal
changed fsb to 210 automatically changed pcie to 105
clock speed 2.94
running test 30 minutes
5 minutes in its at 60c is there a cut off temperature i should know?
10minutes still at 59-60c
15minutes still at 59.5-60c
30m same 0 errors
test ended never went over 60.5c? should i move up another 5mhz?
Maximum operating temperature (°C) ? 55 - 71(googled it)
Starting test 2.
fsb 215
Clock speed 3.01
5 minutes in 58.5c
15 minutes in 57-58.5c
20 minutes 59.5c
25m 59c
test completed 0 errors
test 3
fsb 220
63c 0 errors clock speed 3.08
Arctic Pro 64
Amd ii 630
in bios.
update1-
orginal
clock speed 2.94
30m same 0 errors
Starting test 2.
fsb 215
Clock speed 3.01
5 minutes in 58.5c
20 minutes 59.5c
25m 59c
test 3
fsb 220
