Alright so I ordered all my parts and put my first PC together the other day. Then I go to hook up the monitor and realize that my monitor only has a vga port while the graphics card (9600 gso) is a dual link dvi port. So I am wondering if there is a cable or something capable of converting the vga into the dual link dvi. I have had a hard time searching for one online seeing as there are so many different types. I would really appreciate any help.
there should be a DVI to VGA that comes with the graphics card. but if there isn't you should be able to buy a converter, it shouldn't cost you that much.
------------------------------If fate really does exist, she hates my guys....
Reply to pinaplex
