Yes, it will work just fine.
Just make sure to flip the red switch to 220w before plugging it in.
A trick I learned when I moved to Germany...
Bring a US plugged power strip or two with you.
When you get to Europe, you can get a standard US => EU plug adaptor for about 2€.
As most electronics (everything, including the monitor, I brought with me anyways...) can auto switch to 220v, you can continue using your current devices/plugs with no change.
Just make sure and check the labes before plugging anything in to be 100% sure.
Also, be sure and disassemble and properly pack your PC components before the flight.
Those damn throwers are quite rough with the baggage, even when marked fragile
Best luck with the move!
