Tom's Hardware > Forum > Motherboards & Memory > Asus > I need help with a problem... Please
My PC use to run the memory in dual channel mode.. I was looking at the post and it say single channel mode. I have switch the sticks around different variations still single channel mode. My memory is apacer pc-6400.. 800mhz but cpuz says it's 400mhz.. Maybe my board is messed up. My bios is up to date and I'm at a loss on this one.. Any Idea's????
Sponsored Links
I had that problem too, got a asus m3a79t deluxe mb, the solution should be in the over clocking settings.. You need to change the speed of the memory manually, and set so that the motherboard uses the dual channel feature..
Reply to holycowimanoob
Go to the BIOS and search for the memory options. Usually called "Ganged Mode" then enalbe it and then it will be fixed
Reply to Dur_TriX
I fixed it.. I had a bad stick of ram.. thanks
Reply to christop
There are 1366 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ishaan won the Uniformed badge
  • 01:00 nofun won the Uniformed badge
  • 01:00 ElMoIsEviL won the Spy badge
  • 01:00 mparham won the Freshman badge
  • 01:00 ishaan won the Freshman badge
  • 01:00 Mario097 won the Uniformed badge
  • 01:00 timobkg won the Freshman badge
  • 01:00 ethr won the Freshman badge
  • 01:00 amirp won the Freshman badge
  • 01:00 steelmartin won the Freshman badge
