Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Please verify this mobo is compatible with this power supply
Forum Motherboards & Memory : General Motherboard - Please verify this mobo is compatible with this power supply
This motherboard has an 8-pin connection in the back, near the ps2 ports. Is this an EPS 12 volt connection?
http://www.newegg.com/Product/Prod [...] 6813128387
The power supply looks like it has two 4-pin connectors that can be combined to fit the 8-pin connector on the motherboard...?????
http://www.newegg.com/Product/Prod [...] 6817171037
Thanks,
-Nathan
Sponsored Links
I'm not recommending this PSU I'm merely answering your question. The above combo will work allowing you to use the 8 CPU connection. This PSU has a: CPU 4+4 Pin x 1 option. In your case just use both side by side.
http://www.coolermaster.com/produc [...] il&id=4202
Reply to starams5
- 0 +
cool; thanks!
Reply to natesi
There are 1402 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
