Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Intel d975xbx2 front audio panel help!
Forum Motherboards & Memory : General Motherboard - Intel d975xbx2 front audio panel help!
I have an Intel D975XBX2 motherboard and my case has front audio panel wires.
The front panel audio wires inside my case are as follows:
EAR_1_L
EAR_2_L
EAR_1_R
EAR_2_R
GND
MIC(WHERE DOES THIS ONE GO????
I am puzzled about were the microphone wire would plug into..... I have it setup how I should have it EXCEPT the MIC wire isn't plugged in because I have no idea where it goes.
Below is a diagram of how it should be setup, following a link!
For AC97 Front Panel Audio
1 MIC Front panel microphone input signal (biased when supporting stereo microphone)
2 AUD_GND Ground used by analog
3 MIC_BIAS Microphone power / additional MIC input for stereo microphone support
4 AUD_GND Ground used by analog audio circuits
5 FP_OUT_R Right channel audio signal to front panel (headphone drive capable)
6 FP_RETURN_R Right channel audio signal return from front panel (when headphones unplugged)
7 AUD_5V Filtered +5 V used by analog audio circuits
8 KEY No pin
9 FP_OUT_L Left channel audio signal to front panel (headphone drive capable)
10 FP_RETURN_L Left channel audio signal return from front panel (when headphones unplugged)
http://www.intel.com/support/mothe [...] 015851.htm
I have my EAR_1_L plugged into port_1_L
I have my EAR_2_L plugged into port_2_L
I have my EAR_1_R plugged into port_1_R
I have my EAR_2_R plugged into port_2_R
GND is plugged into GND
So where does my mic go????
Sponsored Links
There are 1066 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
