Recently my PSU die suddenly while surfing the web because I upgrade to more power hungry components so now I have to buy a new PSU and I found this one in newegg called OCZ GameXStream, it has 4 rails on each +12v rating 18A, 600watts. My question is can this PSU enough for my system's spec?
Vista Business
Geforce 8800 GTS 512MB
Intel Qual-core Q8200
2GB SDRAM2
3HD 7200 RPM
I'm more or less just worried about the 600watts being not enough.
Plenty of power.
My estimates:
CPU: about 8 amps @ 12 volts, my Q6600 OC'd to 3.6 GHz pulls 9.5 amps (measured)
Video card : about 9 amps @ 12 volts
RAM: 3 amps @ 3.3 volts (measured)
3 HD's: no more than 3 amps @ 12 volts, 3 amps @5 volts
Motherboard: no more than 5 amps @ 5 volts and 2 amps at 12 volts
Fans: 1 amp @ 12 volts unless you have a lot of fans.
Actually something like a 450 watt Corsair PSU will be plenty.
Just a comment:
Hmmm. 4 Rails - 12V @ 18A. 4x12x18 = 864W and thats not counting the 3.3 & 5V rails. Some 600 W PSU. The PSU can not even supply 3 12V rails @ 18A. Wish they would provide more realitic spec.
I also went over to the OCZ web site looking for info about their 700 watt version. Turns out the GameXtreme series are for mainstream users. They have two other series for high performance.
Just a comment:
It has 4 12V rails that each can individually provide a max of 18A, with a combined 12V max of 580W (~48A combined). While unusual, this isn't an unrealistic spec.
WR2. Read between the lines, and I repeat No way in H will you be able to get 18A on four rails - Not even 3 Rails @ 18A, and do not use forth Rail - Just a marketing ploy
cji
I dought you could get a usable 580, more like approx 550W, could be less. And that is at close to 100%. The 580 includes the +3.3 and +5V rails. This would equate to an average of approx 11.5 A if load was equally divided. Or say 15A on V1&2 leaving only 8A each for V3&4. They could very easily set it up for 18 Amps each on V!&2 and then lower the current limit to a more realistic value. But then that hurts advertizing
NOT knocking PSU - Just the marketing! But then that hurts advertizing
You might have a point if it was marketed or advertised as a 864W PSU. But it's not.
You're confused about the difference in it's technical specifications / capabilities and its marketing / avertising.
If OCZ was pulling any marketing or advertising shenanigans, if it was doing anything different from other PSU makers, you'd certainly hear about that in the professional reviews like the ones shown on OCZ product website .
WR2
Don't think I'm confused. It is advertized as having 4 x 18 Amp rails. Which is correct AS Long as you do not try to use at that load. Almost all PSU's manuf do this. You then have to look at the full specs, ie it's only 600 W total and only 580 W total for +3.3/+5/+12. The majority will not exceed the REDUCED limitations; However, I would prefer to have a spec like 18A, 18A, 8A, 4A (combination to equal realistic Values. But alas also has drawbacks - the used would have to know which goes where and "left over (like roll over min)" would not be available to another rail.
I have one that uses three different current regulator in its 3 x +12V rails and all three rails can be run at their Max listed Rating.
This doesn't sound confused to you? Ok, perhaps you were trying to confuse someone else.
A "realistic Value" is calling a +12V4 18A rail 4A? And it would be realistic because you feel good about that number?
Hardly makes any sense if you plan to power your GTX 275 off the +12V4, though, does it? I wonder what the PSU manual says is the maximum Amperage that rail can provide.
You should take your own advice and look at the full spec instead of picking one part of it and whining about it.
I think you're definitely confused about the difference between advertising/marketing and technical specifications.
