Hi guys. I recently put together a new computer, and its running fine right now. I got a Athlon II X3 440 as its perfect for my needs already, but I still decided to try unlocking it. Running ACC worked and I got into Windows 7 and see that CPUID call it a Phenom II X4 B40. I tested it with Prime 95 and it ran fine for multiple hours. So I figured I got a legit 4 core CPU.
That was until I turned off the system and then tried to turn it on. There the Computer would turn on but not post or get into BIOS. After playing around, I find that the only way to turn it back on is to cut the power, plug it back in, then turn it back on. Then the computer can run fine. Various testing shows that this is only necessary when I'm enabling ACC. I guess what I am wondering is whether there is anything I can do to make the computer run with the Athlon II X3 unlocked, or is my luck not as good as I hoped?
The rest of my system if anyone cares...
Mobo + Optical Drive: Biostar A785G3 + Sony Optiarc CD/DVD Burner Black SATA Model AD-7260S-0B - OEM
http://www.newegg.com/Product/Comb [...] mbo.418256
CPU: AMD Athlon II X3 440 3.0Ghz AM3 OEM CPU
http://www.tigerdirect.com/applica [...] CatId=4919
CPU Fan & Heatsink: Cooler Master Hyper 101A
GPU: XFX ATI Radeon HD 5770 1 GB DDR5
http://www.amazon.com/XFX-Radeon-D [...] 048&sr=1-2
RAM: G.SKILL 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600)
http://www.newegg.com/Product/Prod [...] 6820231253
HDD: Western Digital Caviar Blue WD5000AAJS 500GB
http://www.newegg.com/product/prod [...] 6822136178
PSU: Antec EarthWatts Green EA-380D Green 380W
http://www.newegg.com/Product/Prod [...] 6817371033
Case: Rosewill R102-P-BK 120mm Fan MicroATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811147111
Front Case Fan: Bgears B-Ice Silver 120mm Blue LED Case Fan
http://www.tigerdirect.com/applica [...] Case%20Fan
Thanks for any help in advance
