Yes No
Ads
Tom's Hardware > Forum > Overclocking > CPUs > New Mobo - Q6600 - kingston 1600mhz DDR3 - help!
Forum Overclocking : CPUs New Mobo - Q6600 - kingston 1600mhz DDR3 - help!
Hey awesome folks!
I've been lazy, but I decided, yesterday to wash the dustfilters, clean the side panel, do some descent cable management and put the fans in the right way so that there is a good airflow, temperatures improved like hell actually...
I'm wondering what the best solution for a 3ghs or maybe 2.8ghz OC for my setup...
*NZXT Lexa Blackline case with 3x 120mm fans and 2x 50mm fans (3 intake 3 exhaust)
*ASUS P5E3 Deluxe
*Q6600 stock cooler
*RAM
4GB 1600MHz DDR3 Non-ECC CL9 DIMM (Kit of 2)
Specification Standard 256M X 64 Non-ECC 1600MHz 240-pin Unbuffered DIMMDDR3, 1.7-1.9V, CL9, FBGA, Gold
Form Factor Memory Module
Pieces/Unit 2 (Two 2GB modules, totaling 4GB)
3 sata HDD's
XFX 9600 GT
I've had a stable 3ghz overclock before but It was with a bad cable management and so on.
Any suggestion or idea is highly appriciated!
Thanks.
-Afflicto
Reply to afflicto
You can easily do that with simply raising the fsb without touching the voltages. I prefer a decent aftermarket cooler. This is an inexpensive one that gets rid of that flimsy 775 socket push pin setup:
http://www.newegg.com/Product/Prod [...] ster%20520
You will need to make sure you have room for this one as its a fairly tall heatsink. There are other good ones for a similar price. Get some arctic silver 5 thermal paste too...
Reply to englandr753
well if you've previously had it at 3ghz then just use those settings...You could very well push it further if your temps are good or u get a new heatsink. or if you're happy with 3ghz, just try lowering your Vcore to get it running more efficiently
------------------------------ Intel C2Q Q6600 (OC 3.6Ghz) | Corsair H5O | EVGA GTX470 + 8800GT PhysX | Asus P5N-D | 4GB HyperX | 2x 500GB WD raid0 | 800Watt Gigabyte Odin PSU | Asus 4x Blu-Ray | CM HAF 932 | 28" ViewSonic | 3D-Vision H5360 Projector | Win7 64b | Razer Mamba/ Reclusa
Reply to Baracubra
There are 1476 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
Will this be a good build to overclock 2500k to 5.0GHz?
By DJDeCiBeL, 17 hours ago:
I'm the one that told him that a Silver Arrow will get to 5Ghz, so I'll take the blame...
Best offers
Top experts
