I'm trying to build my first computer and want it to last about 3+ years. I will be doing some light gaming, and converting videos and burning. My budget is around $1k for the computer parts and planning to buy a 22'' monitor.
CPU: Intel Core 2 Quad Q6600 Kentsfield 2.4GHz $189.99
HD: Western Digital Caviar Black WD6401AALS 640GB $79.99
Motherboard: GIGABYTE GA-EP45-UD3R $119.99 - $15 rebate = $104.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128359
Video Card:SAPPHIRE 100259-1GL Radeon HD 4870 1GB $239.99 -$10 rebate = $229.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102801
PSU: CORSAIR CMPSU-650TX 650W $99.99 - $20 rebate = $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Memory: G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
Burner: Suggestion- Samsung?/Lite-on?/LG?/Sony?
CPU cooler: Suggestion
Case: Antec 300/suggestion
Questions:
1. If I don't really game that much, so would it better of getting the 4850 and do I need crossfire in the future to play games. I'll be probably playing SC2, and some other games.
2. For the Memory I see people on the forum say go with DDR2-800 rather 1066, and some say 1066. So what is the better choice.
Thanks in Advances~
Questions:
Thanks in Advances~
