Hi everyone, thanks in advance for your help!
I have a cooler master HAF-932 running with the standard fans, having clocked the CPU about 19% it's running a little hot in the warmer weather so I'm about to add a Noctua NH-D14 (once it gets here) but moving beyond that I need to add a fan controller as the motherboard is running at 46c and I'm wondering if it's worth replacing the 120mm fan blowing air at the motherboard with four smaller fans...
- What's the best bang for my buck for a fan controller?
- Are four smaller fans better that one large one?
- Generally I'm told Noctua or Scythe fans are the best one's, is this true?
Cheers
Cheers
