Sign-in / Sign-up
Do I have enough power for my build?
  • New Build
  • Power Supplies
  • Power
  • Systems
  • Product
Last response: in Systems
January 14, 2009 3:09:13 PM
Hey all, was wondering if the power supply I have picked out is enough to power this stuff in addition to a couple 180 mm fans and a couple 120 mm fans. Will most likely be doing some overclocking, nothing too extreme though. Any other critiques or comments on the build are welcome as well.
GIGABYTE GA-EP43-DS3L LGA 775 Intel P43
Intel Core 2 Duo E8500 Wolfdale
MSI N260GTX-T2D896
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066
Western Digital Caviar Black WD5001AALS 500GB
LG Black 22X DVD+R
and lastly the power supply in question, chosen for its single rail and 2x 6 pin pcie connectors, is 750w enough?
PC Power & Cooling S75CF 750W EPS12V
More about : power build
January 14, 2009 3:37:11 PM
That is probably too much. I have a very similar system (only real difference is that I have a 4870 1gb vid card), and I run very nicely on a 650 watt PSU (Corsair). I'm also overclocking my E8500 to 3.8 Ghz.
You can probably use a name brand PSU rated at 550 watts and be fine.
a b ) Power supply
January 14, 2009 4:02:37 PM
Get a SATA burner.
The PSU is just fine. You'll only use it around 50% capacity, but that's where it's most efficient so it's not a bad thing. Also, $80 for that PSU is a steal. I paid $200 for mine last year.
Are you sure the GA-EP43-DS3L has all the features you will need? There are better boards with lots of extra features for $30 more, like the GA-EP45-UD3R or GA-EP45-UD3P.
$65 more buys you a faster version of that GTX 260 (216 processors instead of 192), with lower power consumption, from a more reliable manufacturer (XFX), and with a copy of Far Cry 2. I think it's worth it, if you're interested in Far Cry 2.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150330
January 14, 2009 5:21:01 PM
Thanks for the input and quick replies guys.
I was actually looking at the GA-EP45-UD3R as a possible upgrade for easier more reliable overclocking. Will probably go with it now.
Why the bigger HDD selection? Just for more storage space? If so, I can always pop in another 500 Gb when I need to. Space really isn't a big concern ATM.
I'll prolly stick with the 750W PC Power and Cooling PSU. $80 (after rebate) seems like too good a deal to pass up.
a b ) Power supply
January 14, 2009 5:43:05 PM
That bigger HDD is faster (higher density platters) and costs less per GB (8 GB/$ instead of 6.66 GB/$). It is a good idea IMO.
a b ) Power supply
January 14, 2009 6:02:12 PM
JustinM75 said:
...Why the bigger HDD selection? Just for more storage space? If so, I can always pop in another 500 Gb when I need to. Space really isn't a big concern ATM...
It's not space, it's speed. The WD6401AALS is much faster. The $$$ difference is peanuts.
January 14, 2009 8:12:41 PM
Nice, I'll swap that out then.
January 14, 2009 9:14:56 PM
Agreed here, good choice of PSU and good call on the HHD as well
a c 144 ) Power supply
January 14, 2009 11:46:28 PM
I bought an eVGA GTX260-216 on sale from newegg in December for $220. There are some good deals out there.
January 14, 2009 11:52:33 PM
I prefer to run my PSU's at 50% - 60% - better efficiency and they run cooler.
In the 500 - 800 GB HD size, the WD 640 is the one to get. Two 320 GB platters will be faster than two or three 250 GB platters.
