Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > GPU disabled in hardware/device manager = power consumption?
Forum Graphic & Displays : Graphics Cards - GPU disabled in hardware/device manager = power consumption?
Let's say I can't stand high idle power consumption, and I'm willing to put up with all the hassle involved with disabling one of 2 gtx295's in device manager during regular use, only to enable it and re-enable sli before gaming.
Will this stop that second video card from drawing it's ~60 (assumption) watts of idle power? Or would I literally have to rip the thing out and just leave it ontop the case?
Sponsored Links
As long as any device is still connected, it will draw some amount of power.
------------------------------ Q9450 |Corsair XMS 4GB DDR 800 | ABit IP35 Pro | HD 5850 | Audigy 2 | Seasonic S12 550 | Cooler Master Centurion 532 | NEC LCD2690WUXi and Planar PX2611w | WinXP
Peace on Earth by means of the destruction of all life on Earth.
Reply to jaguarskx
You're running quad sli and you are concerned with power consumption? :lol: :pt1cable:
Reply to orangegator
You are asking how to save power on a +$400 video card? ROFLMAO
Serious answer: No, zero difference whatsoever. The GPU runs through its startup routine at system startup and stays running with or without an OS claiming control. If it didn't do this you wouldn't be able to see your BIOS for example.
Reply to VTOLfreak
Over where I live it would make the difference between paying an extra $400 a month or not.
And for context the quad SLI is for CUDA.
Reply to FrizzleFry
I very much doubt that. At a high $0.17/kwh, the extra 60W idle running 24/7 would cost you $7.40 per month.
There are 1280 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
