Tom's Hardware > Forum > Motherboards & Memory > Gigabyte > IDE drives startup problem
New set up with the GA-MA790-X-UD4P board. On the IDE side, I have the DVD-R/W in the boot path. When I hook up an IDE hard drive, neither are recognized. HDD alone and it is recognized. What could I be missing? A jumper issue? (The HDD doesn't have one, but I can't see the DVD jumper setting offhand without powering down.) Thanks.
Message edited by genegold on 06-05-2009 at 08:48:04 PM
Sponsored Links
You have 2 options:
1. Set one device to primary and the other one to secondary;
2. Set both devices as cable select. The device on the middle connector will be secondary and the one on the end connector will be primary.
Reply to GhislainG
- 0 +
Here's an IDE cable:
M|----------|------|D
M1---------2-----3D
The 'M' end is the motherboard connector; the 'D' end goes to the drives.
There are two kinds of cables: 'standard' (on which the drives are jumpered to identify them), and 'cable select' (on which the cable itself sorts out the drive IDs).
If there are no labels (often, a large plastic or fabric 'pull-tab') saying 'master' and 'slave' on connectors 2 and 3, you likely have a 'standard' cable - jumper as follows:
it doesnt matter what connector goes to what; your primary (boot) HDD will need to be jumpered as 'master' [MSTR] on the drive; your secondary (or ODD) gets jumpered as 'slave' [SLV] on the drive.
If there are labels saying 'master' and 'slave' on connectors 2 and 3, you have a 'cable select' cable - jumper as follows:
Both drives get jumpered as [CSEL] on the drive; your primary (boot), or only, in the case of just one, goes on connector 3, which should be labeled 'master'; your secondary (or ODD) goes on connector 2, which should be labeled 'slave'; connector 1 goes to your MOBO IDE port...
Now, boot, do a <DEL> to get into the BIOS, and go to the 'Integrated Peripherals' page - set 'Onboard SATA/IDE Device' to 'Enabled'; set 'Onboard SATA/IDE Ctrl Mode' to 'IDE'; go to the 'Advanced BIOS Features' page, select 'Hard Disk Boot Priority', and hit <ENTER>; select your boot drive from the list; set 'First Boot Device' to 'CDROM', 'Second Boot Device' to 'Hard Disk', and you should be good to go...
Reply to bilbat
M1---------2-----3D
Thanks, but I think you've misunderstood a bit. Neither of these are Windows system boot drives, except the DVD in a pinch; the HDD is just for getting some files off now and backup later. I just want to be able to get two IDE devices to be recognized and was only getting one to work at a time, with two not at all. As both you suggest, it sounds like a jumper issue. Does it matter which is master and which is slave, given the set up I'm suggesting? (XP is starting off a SATA drive.) Thanks.
Reply to genegold
- 0 +
I've always set the HDD as 'master', and the ODD as 'slave', but I think it's probably just a 'grandma always did it that way' thing - I've probably got underwear that's been a dust rag longer than you've been alive. Way back when, it was the only way they'd work; now, I don't think it really matters. What does matter is - if your cable is 'cable select', your drives both have to be jumpered as 'CS', and if it's a standard cable, one must be jumpered to 'SL' and the other to 'MA'...
Reply to bilbat
Thanks, I'll try one or the other. Either you're as much a collector of cloth as my mother was with newspapers, or you don't turn over underware very often. ;-) I'm old enough for Gene Barry's War of the Worlds to have been my first visit to the movie theater.
Reply to genegold
- 0 +
Haw haw! And aren't the recent pair a couple of crappers? The first one I recall clearly was "The Time Machine" - at a drive-in (try to find one of those now!), where my Mom covered my eyes when he 'fast-forwards', and the Mollochs decay around him - guess she thought rotting eyeballs dropping out might be traumatizing...
Reply to bilbat
Oh, you're a young un'; the film version of The Time Machine came out in 1960. Thanks for your help.
Reply to genegold
There are 1255 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
