Question about HAF case bottom side PSU mount
Hey i just received my brand new computer components. Included was a HAF case. It's designed for bottom mount PSU supply.(You can do top mounted PSU supply but the nyou loose a 230MM fan).
Anyways ive seen it suggested that for Bottom mount psu you install the psu upside down. My question is how necessary is this? To install the PSU upside down i will have to do some modding it looks like. I'd rather just install it right side up. Thanks guys!
1 answer Last reply
More about question case bottom side mount
  1. There is a mesh at the bottom where the CPU goes but with the CPU tray and mesh it doesnt seem like it would get good airflow. Anyway starting build hopefully i wont have to strip the case later to do some drilling. Thanks.
Homebuilt Cases Computer Components Systems
