im using MSI GD-70 Mobo...
my problem is sometime the LAN suddenly pop out limited connectivity(i mean my connection) and im dc from internet and then i need to plug my cable to the other LAN to continue surfing because this mobo got dual LAN..
anyone know why this happen??
------------------------------AMD Phenom II 955 3.2Ghz
MSI MS7577 AMD 790FX-GD70
Sapphire ATI HD4890 1GB DDR5 x 2
Kingston Hyper-X DDR3 1600MHz 2GB x 4
Is the 1 of the Lan is for 1000 Mbps and the other 1 for 100 Mbps??
anybody know please do help me coz i can only use 1 of the Lan adapter..no point i got dual Lan if i only can used 1 of them...thanks..
Reply to cheer86
go into 'My Network Places' then click 'View Network Connections' then right click on local area connection and view properties. scroll down and look for internet protocol, view the properties of that and make sure that the boxes are all grey.
Now i cant use the 1 of the adapters for internet connection..it keep saying limited connectivity..i can use the other 1 adapter only for 100 mbps connection..this is really weird..what happen?
Reply to cheer86
