Tom's Hardware > Forum > Motherboards & Memory > MSI-Microstar > XP OEM shut down Problem
I installed XP Home on a Biostar M7VIG Pro / ATH 2100 CPU combo. After setup, validation and updates I discovered a problem with USB and also I got a" Its safe to turn off your computer" on shutdown error. I confirmed USB in the bios reinstalled XP from windows and searched MS knowledge base for answeres but nothing helped. I switched Hard drives and installed another OS. Same problem. I switched main boards to MSI MS 6390,same problem. The USB sort of works sometimes but seems like there is a conflict when it does, yet device manager says no. I had to call MS to reactivate last time and dont know how many times they will let me do that. Whats wrong and how can I fix it? The only thing common to all the variations is a Emachine USB card reader. I checked the pin out on the connector and its OK plus the reader sees SD cards without any problem. Its just the front and rear USB ports that dont work.
Message edited by don leja on 06-09-2009 at 02:55:55 PM
Sponsored Links
There are 553 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
