Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > HELP with motherboard/perhaps cpu!?!?!
I got an ECS K8M800-M2 micro motherboard in my computer that had an AMD Sempron 2800+ 754pin processor and a 512mb 184pin memory stick. I recently bought 2- 1gb 184pin memory sticks and an AMD Athlon64 3000+ to upgrade just a little bit. No trouble what so ever replacing everything, was all ready to go and when I turned the computer on, nothing. So I checked to see if everything was seated properly and whatnot. Everything checked out OK. Turned the computer on again and nothing. The HSF and power supply fans both ran, my 2 disc drives ran. The power light came on, but no noises, flashes, or anything. The flashing light on the front next to the power light (I forget what its called, flashes when your working around, loading programs, etc...) didn't come on what so ever. So I put the old processor and memory back in... NOTHING!! Just tried replacing the battery, that wasn't the trick. So question is... do I have a dead motherboard now or did I happen to crap out both processors? I unplugged EVERYTHING before hand, so I'm hoping plugging everything back in didn't do harm to anything. Any and all help/advice is very much appreciated.
Thanks!
Sponsored Links
If possible tear everything out and do a rebuild. Problem like this normally takes a long time to troubleshoot and there's way too many things to check. By doing a rebuild you're checking everything along the way as you go.
If that still doesn't work try operating the motherboard, CPU, RAM, gfx card and HDD out of the case on something like a wooden desk.
Also what about simple things like plugging DVI/VGA cable in and making the LCD/monitor is powered?
Message quoted 1 times
Message edited by wuzy on 06-08-2009 at 08:46:37 AM
------------------------------ GTL Ref Tweaking Guide - PM for detail
Brand is for the weak-minded, only product matters.
Resilient to marketing.
http://farm3.static.flickr.com/2520/3850950213_aea6bbbcfe_o.jpg
Reply to wuzy
What version of this board do you have? If you have version 1.0 or 2.0, I think you will need a BIOS update to support the 3000+ CPU. Go to the ECS site here and check it out.
http://www.ecs.com.tw/ECSWebSite/P [...] =1&LanID=0
Reply to jitpublisher
- 0 +
I don't know exactly, but I believe the computer is in the 3-4yr range. So I would guess version 1.0 or 2.0?? But how would I run the update? Nothing shows up. Again, the hsf and power supply fans run, my cd/dvd drives run and the idle light I guess it would be doesn't come on. Only the power light is on.
Reply to ratzer
- 0 +
Every time I went to go turn the computer on to see if I fixed it, I plugged all the basic stuff in just to see if it worked ie. keyboard, mouse, monitor, speakers and power supply.
Reply to ratzer
try the old RAM. are the speeds the same? the RAM bus shouldn't be faster than the Processor FSB
Message edited by Upendra09 on 06-09-2009 at 01:42:07 AM
Reply to Upendra09
There are 918 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
