Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 4830 causes monitor to go into power save mode help!
Forum Graphic & Displays : Graphics Cards - 4830 causes monitor to go into power save mode help!
I have a dell core 2 quad 6600, 4 gb ram, integrated video/audio ...g45 chipset on windows vista 64. i just bought an asus hd4830 and the computer booted fine...but after installed catalyist drivers it boots up and the screen goes to power save mode....I can boot up into safe mode and uninstall it and then boot it up again fine....i have tried downloading the newest and what the asus card came with...does the same with both....what can I do>
Sponsored Links
oh, and It goes into power save mode after the windows driver bar is done...when the next screen should be windows desktop...is when it goes into power save mode.
Reply to zoenphlux
Same problem here. Monitor goes into power saving mode just before the login screen appears.
Fresh install of 32 bit Windows XP Pro with SP/3 and the latest drivers dated Feb. 20, 2009 did not resolve the issue.
My card is the SAPPHIRE 100265HDMI Radeon HD 4830 512MB
Driver package: 9-2_xp32_dd_ccc_wdm_enu_75974
I was able to get the drivers to load successfully one time (after restarting from a safe mode session) and that appears to have been a fluke- the problem reappeared with the next reboot.
Any help would be appreciated.
My system
GIGABYTE GA-MA790X-UD4 Motherboard
AMD Phenom 8650 Toliman 2.3GHz Socket AM2+ Processor
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 memory
Rosewill Stallion Series RD600N-2SB-SL-BK 600W Power Supply
No over clocking has been performed on the system, all stock settings.
Reply to JoeCorrado
There are 1073 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
