G
Guest
Guest
Hi.
I've got problems with my external harddrive from Iomega. (500gb).
When I connect it to my computer (Windows Vista 32-bit), It appears in "My computer" like it's supposed to, but when I open it, all maps in the drive are "Shortcuts" instead of "Filemaps". When I try to open a map in the drive, nothing happens, and after a moment I get this strange thing called c.exe wanting to acces my computer.
I think my harddrive has been infected by some sort of virus or something, but I really need the data from my drive, because it's about 260 gbs I've put into it.
I need help how to fix this!
If someone have an idea, I would appreciate if you posted a reply soon!
Greetings, Anton
Greetings, Anton
