Tom's Hardware > Forum > Motherboards & Memory > Memory > TRIPLE CHANNEL MEMORY - SPEED DIFFERENCE
System Model : XPS 435 MT
Memory : 3x2GB of DDR3 memory with 1333MHz.
I have 2gb of 3 memory sticks - total speed shown is 1066 MHz instead of 1333 MHz
Tried populating memory in combinations of 135 & 246 , made no difference to the speed
As per Triple Channel configuration, 3 memory sticks of 2gb each , total of 6 gb on slot 135 or 246 should show 1333 MHz not 1066 MHz
Pl advise
rgds
KIRAN TJ
CompTIA A+ | DCSE (M) | Six Sigma (YB) | MCSE | MCP| DCT (M)
Message edited by KIRAN TJ on 06-09-2009 at 03:00:52 PM
Sponsored Links
By default X58 and i7 920 run memory at 1066mhz. You'll need to go into the BIOS and change the default memory multiplier from 2:8 to 2:10, that should equal to 133mhz x 10 = 1333mhz RAM.
Reply to flyin15sec
- 0 +
As for the rated speed: The SPD chip on your RAM provides a number of potential settings, and your computer's Bios has chosen the default. If you don't like that it's showing a different number, then set your memory divider appropriately. 2:10, as Flyin indicates.
As for any difference in speed... You may not want to bother, since there is little/no performance gain associated by running higher clocks:
http://www.tomshardware.com/review [...] ,2325.html
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
Amazing guys, got this working now ! -
This is one of the best & fastest reply I ever had
Good luck & thanks again :)
Kiran T.J | CompTIA A+ | DCSE (M) | Six Sigma (YB) | MCSE | MCP| DCT (M)
Reply to KIRAN TJ
There are 880 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
