Tom's Hardware > Forum > Graphic & Displays > ATI > Dual Sapphire 4870x2 Crossfire Questions...Help
Forum Graphic & Displays : ATI - Dual Sapphire 4870x2 Crossfire Questions...Help
I just built my Core i7 gaming system:
Core i7 920
Gigabyte UD5
6 gigs ram
1000 watt PSU
I bought my first Sapphire 4870x2 a month ago, and the clocks in ATI Overdrive go up to 800 GPU / 1000 MEM
I just put my second Sapphire 4870x2 in tonight to crossfire, and this card says it's clocks only go to 778 GPU / 980 MEM
What is up with that? How can the exact same card and manufacturer have different clocks?
I am using CCC 9.1
Another thing, in CCC when you go to 3D settings, when i first installed CCC the little menu's had a animations, now it's just a still frame picture. Is there a bug in this driver?
Sponsored Links
Every piece of hardware is going to be slightly different. Just how the same model of CPU will overclock to different speeds.
I would assume this comes about from something in the creation process, but maybe someone who knows will post.
------------------------------ This planet will burn good. It has lots of critters on it. Critters burn good...
http://valid.canardpc.com/cache/banner/552078.png
Reply to bonanzaguy
- 0 +
Can anyone else comment on this clock issue?
Reply to wick001
- 0 +
@ Bonanzaguy: That's a piss poor bit of advice you offered
Mate check out the AMD forums: http://forums.amd.com/game/message [...] erthread=y
There is a problem with quad Xfire - ie two X2 cards - whereby only 2 GPUs are recognised. Check out the newest threads on that forum
Reply to fruees
- 0 +
Thanks... I've researched a ton on this issue, and really can't find much.
I've noticed the bios version of the first 4870x2 I bought is older than the second.
Again, In Cataylst ATI Overdrive, why does one card's OC ability go to 800 gpu/1000 mem and the other only to 780 gpu / 980 mem? Same cards, Same manufacturer
Message edited by wick001 on 02-26-2009 at 07:24:26 AM
Reply to wick001
- 0 +
Why does it matter? They won't overclock the same, and as long as they are running just fine, I don't really see a significant issue.
Now, if only 2 GPUs are recognized, that's a different issue.
------------------------------ Asus P6T deluxe
i7 965 @ 4.2GHz (200*21), 1.384V
12GB Corsair Dominator DDR3-1600 CAS 7
Reply to cjl
There are 958 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 vianescute won the Freshman badge
  • 01:00 meywd won the Freshman badge
  • 01:00 nayega won the Freshman badge
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
