Sign-in / Sign-up
A BIG problem with underclocked processor
  • CPUs
  • Processors
Last response: in CPUs
April 17, 2009 1:33:29 AM
Howdy to everyone!
I just bought a nice new computer. First everything was fine, i play alot of counter-strike:source, fps was 299-300. Now the fps dropped to 30-100, and i have discovered that the corespeed of my processor is 2000.0, and multiplier 6x.
Its intel core 2 duo 8400, the clock shoud be 3000.0 and 9x. I think the processor is in idle mode or something, and i think i should update my BIOS, but i cant find any updates for the motherboard i have (Asus 775 LGA P5Q PRO). if i start packing a file into a RAR, the clock goes to 3000 for sometime, but gets back to 2000 immediately.. this is annoying and i have speedstep disabled and tried to disable C1E also... buff.. what should i do O_o
-Panicci
More about : big problem underclocked processor
a b à CPUs
April 17, 2009 1:53:21 AM
If you are positive you have disabled SpeedStep, then there is the chance your CPU is overheating.
a b à CPUs
April 17, 2009 2:29:49 AM
Did you have a power outage or anything like that? I know that sometimes my BIOS will reset if we have a bad electrical storm and the power flickers a lot. You'd think at this point I'd finally buy a UPS.
But why would you disable SpeedStep? It's made so that it can't hurt performance, but only save power.
a b à CPUs
April 17, 2009 11:29:05 AM
^It can lead to instability when not running at stock speeds.
