Building Enclosure HELP!!!
comment/suggestions?
Rosewill RX35-AT-SU3 BLK Full Aluminum Cover, Metal Tray 3.5" Black USB 3.0 External Enclosure
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182223
WITH:
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136533
OR:
Put the above listed hard drive in my computer, because my motherboard supports sata6- and put the one in my computer
(Western Digital AV-GP WD5000AVDS 500GB 32MB Cache SATA 3.0Gb/s)
(http://www.newegg.com/Product/Product.aspx?Item=N82E16822136497)
in the enclosure?
thanks for the help?
1 answer Last reply
More about building enclosure help
  1. the 1tb drive is probably faster (newer? denser data/more cache) so I would make that my boot drive, if that's what you are using it for internally, as long as the 500gb is enough to back up your data, if that's what your external drive is for.
Hard Drives Western Digital Enclosure Storage Product
