Tom's Hardware > Forum > Motherboards & Memory > Chipsets & Bios > What to do ...bios problem
i was flashing my bios and i accidently hit the power button now it freezes in the bios boot screen but i can hit escape and goes into bios settings but it freezes whe i try to change boot order its a toshiba satalite a135 laptop
Sponsored Links
update well i guess no body has anything to say...
Reply to rblevins4130
Did you try removing the battery for a while or moving the CMOS jumper pins to see if it will default to original settings?
Reply to cmichael138
It sounds like your boot sector is OK, so hopefully someone remembers the keys combo to force a reflash.
Reply to Crashman
my battery is soldered to mobo and what keys? to get it into crisis mode?its fn+b i know the keys i just need to know how to fix i heard of a fix with a 3.5 floppy usb drive but who the hell has one of those?its 2009 it says i can reflash it form the floppy caus eit would only read somthing in a dos enviorment...i have all the programs and disks just no usb floppy :fou:
Buy one? Last I checked they were available for $10 at surpluscomputers.com
Reply to Crashman
There are 624 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
