To sum up what I ened help with:
My Current i7 930 is running too hot ....
My Rig:
Antec 1200 Stock fans @ max speeds via antec 1200 fan controller
Core 17 930 @ stock speeds w/ Arctic Silver 5
Corsair H50 Push Pull Intake
Asus P6X58-D Latest Drivers and BIOS
G Skill Ripjaw Series 6 Gigabytes (2 x 3) Triple Channel XMP used for 2000mhz
Western Digital Raptor (Sata 1) Windows 7 Pro 64bit Installed and fully updated
2 Western Digital Black Caviar 1.5 Terabytes Sata 3 @ sata 2 RAID 0
X-Fi Gamer PCI Interface
1000Watt Antec Power Supply (80 Plus certified)
XFX ATI 5870
My room temp is about 27c - 29c (around 78 -81)
_____
Ok so getting to the issue....
My CPU is at stock speeds, and with my motherboard it throttles the cpu down to 1.6ghz - 1.7ghz per core when not in use (from 2.8 per core)
So ... If I boot into BIOS, it reports that the cpu is 41c and the Board is 32c ... continue into windows and the cpu is idle at 50c, board at c. Under load I am at 70c within twenty mins of gaming (gothic 3 w/ custom ini, or Metro 2033 both maxed settings)
After ten mins or so of the computer idle hot air starts shooting from the exhaust.
I have tried to reseat the proc multiple times, used MX-2 and Arctic Silver 5 (using arcticlean between switching)
These high temps are via: real temp, and core temp ... The strange thing is, is that the asus utilities PC Probe and Asus AI Suite as well as Speed fan report that the CPU is at 34c and Board is at 29c (Im not sure which ones are reporting the distance to tjmax, and the temp itself)
GPU idles at 40c and 70c under load
Cable management and airflow is great
I clean dust filters weekly
I have the side fan blowing in on gpu
Harddrive temps are around 32c (the raid and the raptor)
This is a screen shot of all the temps right now: (keep in mind its raining outside and much much cooler then its been around here in a while so temps are lower than usual) and usually core temp and realtemp show exact same things (50c + @ idle) @ 1.7Ghz per core
Uploaded with ImageShack.us
______________
Im at a loss on what to do .. Im more inclined to trust The real temp and core temp just because before windows starts my temps at 40c and the fact that my room will heat up in ten mins flat.
Any ideas on what the problem is?
Should I RMA the cpu (I just got it a month ago)
Should I get a new Liquid cooling system? (If so what do you suggest)
Help me Toms Hardware, you're my only hope!!
My Rig:
XFX ATI 5870
_____
______________
