Tom's Hardware > Forum > Motherboards & Memory > Memory > Would adding RAM significantly speed up my system?
Forum Motherboards & Memory : Memory - Would adding RAM significantly speed up my system?
I have an i7 system with 2 GTX 275's in SLI running windows 7 RC 64-bit. The loading times and overall smoothness aren't what I would like them to be (nothing wrong with my FPS though). What would be the best upgrade to improve overall system responsiveness? I'm currently on 3GB of Corsair DDR3-1333 ram and a WD 320GB SATA 7200rpm HDD w/ 16mb cache. I have lots of people telling me to get more ram but is 3 more GB of ram really going to make a difference? Maybe I should go with an SSD instead?
------------------------------ Intel core i7 920 @ 3.5GHz
ASUS P6T
Corsair 3GB DDR3-1333
(2x) EVGA GTX 275 SLI
Sponsored Links
how much ram are you currently using ie x/3072
3gb should be enough tho
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
- 0 +
Your HD can be improved to either 32MB cache or SSD. Both will improve performance but I really doubt that if you upgrade to 32MB cache it'll do much.
Also, your memory timings can be a suspect too! 3GB is enough unless you have a ton of processes running. Either overclock and tighten your timings or get more RAM.
Reply to Armi
yes more ram will help, but xaira is right should be enough.
Reply to jdigital1983
A faster hard drive would likely help most with the symptoms you are describing.
That WD 320 16mb cache is not exactly known for it's blinding speed. If you are getting good frames in games, I would say your memory, though you don't have a ton of it, is enough for what you do. I say a fast 1 TB drive will really help.
Reply to jitpublisher
^+1 but ram will probaly be in the future.
- 0 +
Quote :
That sounds like a HDD I/O issue, and not Memory.
------------------------------ Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
There are 977 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
