Motherboard or power supply fried. Can I return it to store?
Last response: in Systems
- SolvedSo my power supply fried my motherboard I need a replacement any suggestions? It is in an apevia dreamer 2 Forum
- my power supply and motherboard are fried Forum
- SolvedUpgrade power supply or return? Forum
- SolvedPower supply surge fried this cable, don't know what it's called? Forum
- SolvedNot enough, return power supply? 430w-500w or 600w? Forum
- Return power supply Forum
- Will I fry my motherboard if I put a 500 watt power supply in a Asus M2N68-LA? Forum
- Can a motherboard fry a power supply? Forum
- SolvedIs My Graphics Card Fried? Or Motherboard? Not Enough Power? Forum
- SolvedCannot tell whether motherboard or CPU is fried only power led on mobo and GPU light up Forum
- SolvedReturning a Power Supply Forum
- SolvedIs the problem the Power Supply of did I fry the Video Card? Forum
- SolvedPicking a Motherboard and Power Supply, need help! Forum
- SolvedI need a power supply and motherboard that can support the Intel Core i5-4690K and a GTX 980 card. Forum
- SolvedWill my power supply work with my motherboard? Forum
- SolvedIs this power supply compatible with this motherboard Forum
- Solvednew gpu making problems in my pc... might need new power supply and motherboard for around £70 Forum
- SolvedDead Motherboard or Power Supply Forum
- SolvedPower supply only has 8 pin CPU cable, but the motherboard only has a 4 pin socket? Forum
- SolvedDId my power supply die, or my motherboard? 2 day old BUild, no signs of life. Forum
- More resources
